Saltar al contenido principal
HP Pavilion dv2913cl Keyboard Replacement
Qué necesitas
  1. HP Pavilion dv2913cl Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Locate battery on the bottom of the laptop.
  2. HP Pavilion dv2913cl Keyboard Replacement: paso 2, imagen 1 de 1
    • Slide the battery release bar to the left, this should release the battery so you can then remove it.
  3. HP Pavilion dv2913cl Keyboard Replacement: paso 3, imagen 1 de 2 HP Pavilion dv2913cl Keyboard Replacement: paso 3, imagen 2 de 2
    • Locate the three screws for the keyboard by finding the small keyboard picture, remove these screws and flip the laptop back over.
  4. HP Pavilion dv2913cl Keyboard Replacement: paso 4, imagen 1 de 1
    • Open the laptop so the keyboard is facing upwards and towards you.
  5. HP Pavilion dv2913cl Keyboard Replacement: paso 5, imagen 1 de 2 HP Pavilion dv2913cl Keyboard Replacement: paso 5, imagen 2 de 2
    • Use the plastic opening tool to get underneath the plastic bar above the keyboard, pry upwards. Pry the keyboard upwards gently.
    • Be careful not to pull the keyboard too hard so you do not rip the silver ribbon cable attached to the laptop.
  6. HP Pavilion dv2913cl Keyboard Replacement: paso 6, imagen 1 de 2 HP Pavilion dv2913cl Keyboard Replacement: paso 6, imagen 2 de 2
    • Release the ribbon cable by using a flathead screw driver. Release the two tabs holding the cable and pull outwards.
    • Pull the keyboard up and out from the laptop.
Conclusión
Una persona más ha completado esta guía.
Adam Braga
Miembro Desde 10/24/16
230 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 2-7, Isaacson Fall 2016 Miembro de UMass Dartmouth, Team 2-7, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G7
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 150
