Saltar al contenido principal
HP Pavilion dv2700 Hard Drive Replacement
Qué necesitas
  1. HP Pavilion dv2700 Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • To remove the battery, pull the tab to the left and lift the battery from the computer.
  2. HP Pavilion dv2700 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Using a #0 Phillips Head screwdriver, unscrew the hard drive cover.
    • The screws cannot be removed from the cover.
    • To remove the cover, lift up and to the left.
  3. HP Pavilion dv2700 Hard Drive Replacement: paso 3, imagen 1 de 1
    • Using a #0 Phillips Head screwdriver, remove the screws holding the hard drive in place.
    • These are the two screws located on the right side of the hard drive.
  4. HP Pavilion dv2700 Hard Drive Replacement: paso 4, imagen 1 de 2 HP Pavilion dv2700 Hard Drive Replacement: paso 4, imagen 2 de 2
    • Lift the tab connected to the hard drive in order to remove it.
    • The hard drive may be difficult to remove by grabbing the tab. In this case, use the spudger to gently pry it from the computer.
Conclusión
2 personas más completaron esta guía.
Jared Opperman
Miembro Desde 09/24/15
161 Reputación
1 Guía escrita
Equipo
Texas Tech, Team 22-6, Rauch Fall 2015 Miembro de Texas Tech, Team 22-6, Rauch Fall 2015
TTU-RAUCH-F15S22G6
3 Miembros
2 Guías creadas
Un comentario
Hi, I have a seagate hard drive that was mounted on a hp pavillon dv series computer. I only have the hard disk and I can not find any serial adapter that can be connected to the hard disk connector. I saw on amazon and ebay but I did not find anything. Can you help me? Thank you!
L. S. - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 19
Todo El Tiempo: 3,073
