Saltar al contenido principal
HP Pavilion dv2000 Wireless Card Replacement
Qué necesitas
  1. HP Pavilion dv2000 Wireless Card Replacement, Wireless Card: paso 1, imagen 1 de 2 HP Pavilion dv2000 Wireless Card Replacement, Wireless Card: paso 1, imagen 2 de 2
    • Make sure your computer is powered down and unplugged from the charger before removing any components.
    • Locate and unscrew the single 3.8mm screw holding the wireless card casing in place.
    • Lift up and remove the wireless card casing.
    • The 3.8mm screw will remain in the wireless card casing after you unscrew it.
  2. HP Pavilion dv2000 Wireless Card Replacement: paso 2, imagen 1 de 2 HP Pavilion dv2000 Wireless Card Replacement: paso 2, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use a pair of tweezers to remove the three antennas from their sockets.
    • Remove the antennas by the contacts connected to the socket, the crimps connecting the wires and the sockets are delicate and are easily damaged.
  3. HP Pavilion dv2000 Wireless Card Replacement: paso 3, imagen 1 de 3 HP Pavilion dv2000 Wireless Card Replacement: paso 3, imagen 2 de 3 HP Pavilion dv2000 Wireless Card Replacement: paso 3, imagen 3 de 3
    Phillips #00 Screwdriver
    $5.49
    Comprar
    • Remove the two 3.8mm screws holding down the wireless card with your Phillips #00 Screwdriver.
    • Gently pull out your wireless card from its top side to remove it from its holding.
Conclusión
3 personas más completaron esta guía.
Erik Muniz
Miembro Desde 09/09/14
820 Reputación
3 Guías creadas
Equipo
CSU Fullerton, Team 2-3, Bruce Fall 2014 Miembro de CSU Fullerton, Team 2-3, Bruce Fall 2014
CSUF-BRUCE-F14S2G3
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 2,212
