Saltar al contenido principal
HP Pavilion dv2000 Keyboard Replacement
Qué necesitas
  1. HP Pavilion dv2000 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 2 HP Pavilion dv2000 Keyboard Replacement, Keyboard: paso 1, imagen 2 de 2
    • Make sure your computer is powered down and unplugged from the charger before removing any components.
    • Remove the ten 8.9mm screws (underneath where the battery would be) holding the keyboard and bezel in place.
  2. HP Pavilion dv2000 Keyboard Replacement: paso 2, imagen 1 de 2 HP Pavilion dv2000 Keyboard Replacement: paso 2, imagen 2 de 2
    • Flip the computer over to the front (keyboard-side up).
    • Gently pop the bezel off by reaching underneath it and pulling up.
    • If you are doing this for the first time, the bezel may require you to exert a little bit more force to remove it.
  3. HP Pavilion dv2000 Keyboard Replacement: paso 3, imagen 1 de 2 HP Pavilion dv2000 Keyboard Replacement: paso 3, imagen 2 de 2
    • The keyboard is held in by three small tabs near the bezel of the computer. Lifting the bezel frees the three tabs.
    • If you are removing the keyboard, the tabs will require a bit more upward force to pull away from the keyboard.
    • Remove the ribbon connecting the keyboard to the computer by pulling back on the ribbon (away from the track pad).
Conclusión
6 personas más completaron esta guía.
Erik Muniz
Miembro Desde 09/09/14
820 Reputación
3 Guías creadas
Equipo
CSU Fullerton, Team 2-3, Bruce Fall 2014 Miembro de CSU Fullerton, Team 2-3, Bruce Fall 2014
CSUF-BRUCE-F14S2G3
3 Miembros
3 Guías creadas
Un comentario
Many THANKS Erik
I am a computer imbecile. I own a hp pavilion dv2000 that is about 10-12 years old.
I may now be able to FIX it and not have to buy a whole new one
phillip james
Phillip James - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 19
Todo El Tiempo: 2,735
