Saltar al contenido principal
HP Pavilion dv2000 Hard Drive Replacement
Qué necesitas
  1. HP Pavilion dv2000 Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 2 HP Pavilion dv2000 Hard Drive Replacement, Hard Drive: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    Phillips #00 Screwdriver
    $5.49
    Comprar
    • Flip your computer over, so that the underside of your computer is facing upward.
    • Make sure your computer is powered down and unplugged from the charger before removing any components.
    • Locate the hard drive casing on the bottom-right corner of your flipped computer.
    • Remove the two 3.8mm screws with your Phillips #00 Screwdriver and carefully lift up and remove the hard drive casing.
    • Screws on hard drive casing will remain in casing after being unscrewed.
  2. HP Pavilion dv2000 Hard Drive Replacement: paso 2, imagen 1 de 3 HP Pavilion dv2000 Hard Drive Replacement: paso 2, imagen 2 de 3 HP Pavilion dv2000 Hard Drive Replacement: paso 2, imagen 3 de 3
    Phillips #000 Screwdriver
    $5.49
    Comprar
    • After you lift off the hard drive casing, using your Phillips #000 Screwdriver, remove the two 3.6mm screws located on the right side of the hard drive.
    • Using your fingers, carefully lift the lower right corner of your hard drive until it is removed from its housing.
Conclusión
7 personas más completaron esta guía.
Erik Muniz
Miembro Desde 09/09/14
820 Reputación
3 Guías creadas
Equipo
CSU Fullerton, Team 2-3, Bruce Fall 2014 Miembro de CSU Fullerton, Team 2-3, Bruce Fall 2014
CSUF-BRUCE-F14S2G3
3 Miembros
3 Guías creadas
Un comentario
You didnt mention this HDD has a different SATA connector , I cant find it in the market, instead of plug in , this one is for pressing down only
tml215 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 27
Todo El Tiempo: 4,246
