Saltar al contenido principal
HP Pavilion dv1000 RAM Replacement
Qué necesitas
  1. HP Pavilion dv1000 RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Shut down the computer.
    • Disconnect all external devices and cables from the computer.
  2. HP Pavilion dv1000 RAM Replacement: paso 2, imagen 1 de 1
    • Flip the laptop over.
  3. HP Pavilion dv1000 RAM Replacement: paso 3, imagen 1 de 2 HP Pavilion dv1000 RAM Replacement: paso 3, imagen 2 de 2
    • Locate the gray sliding tab next to the black bar where the battery is located.
    • Slide the gray sliding tab to the left until you hear a distinct click.
    • The inside edge of the battery should pop up.
  4. HP Pavilion dv1000 RAM Replacement: paso 4, imagen 1 de 3 HP Pavilion dv1000 RAM Replacement: paso 4, imagen 2 de 3 HP Pavilion dv1000 RAM Replacement: paso 4, imagen 3 de 3
    • Grasp the inside edge of the battery.
    • Lift the inside edge of the battery up to detach the battery from the laptop.
  5. HP Pavilion dv1000 RAM Replacement, RAM: paso 5, imagen 1 de 1
    • Locate RAM access door on the bottom side of the laptop.
  6. HP Pavilion dv1000 RAM Replacement: paso 6, imagen 1 de 3 HP Pavilion dv1000 RAM Replacement: paso 6, imagen 2 de 3 HP Pavilion dv1000 RAM Replacement: paso 6, imagen 3 de 3
    • Locate the two screws holding down the RAM access cover
    • Unscrew the two screws with a size 00 Philips screwdriver.
    • Note: The screws do not detach from the cover.
  7. HP Pavilion dv1000 RAM Replacement: paso 7, imagen 1 de 2 HP Pavilion dv1000 RAM Replacement: paso 7, imagen 2 de 2
    • Lift up on the screw side of the RAM access cover to remove it.
  8. HP Pavilion dv1000 RAM Replacement: paso 8, imagen 1 de 2 HP Pavilion dv1000 RAM Replacement: paso 8, imagen 2 de 2
    • Gently pull apart the metal tabs located on both sides of the stick of RAM.
    • The RAM stick should tilt upwards.
  9. HP Pavilion dv1000 RAM Replacement: paso 9, imagen 1 de 1
    • Gently lift the the RAM up and out of its seat.
  10. HP Pavilion dv1000 RAM Replacement: paso 10, imagen 1 de 1
    • Repeat the previous two steps for the remaining stick of RAM.
Conclusión
5 personas más completaron esta guía.
Henry OBrien
Miembro Desde 04/04/11
104 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 10-37, Forte Spring 2011 Miembro de Cal Poly, Team 10-37, Forte Spring 2011
CPSU-FORTE-S11S10G37
5 Miembros
9 Guías creadas
2 comentarios
THANKS - YOU'RE AWESOME!!!! Removing the hard drive was the fix it! the HP site never tells you this - imagine.......
marena - Contestar
I had never dealt with laptop ram before and i used this guide sussusfully to remove the ram from my old HP Pavilliondv6-3055dx laptop. Thanks!
Andrew Lonero - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 8,888
