Saltar al contenido principal
HP Pavilion dv1000 Keyboard Replacement
Qué necesitas
  1. HP Pavilion dv1000 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Shut down the computer.
    • Disconnect all external devices and cables from the computer.
  2. HP Pavilion dv1000 Keyboard Replacement: paso 2, imagen 1 de 1
    • Flip the laptop over.
  3. HP Pavilion dv1000 Keyboard Replacement: paso 3, imagen 1 de 2 HP Pavilion dv1000 Keyboard Replacement: paso 3, imagen 2 de 2
    • Locate the gray sliding tab next to the black bar where the battery is located.
    • Slide the gray sliding tab to the left until you hear a distinct click.
    • The inside edge of the battery should pop up.
  4. HP Pavilion dv1000 Keyboard Replacement: paso 4, imagen 1 de 3 HP Pavilion dv1000 Keyboard Replacement: paso 4, imagen 2 de 3 HP Pavilion dv1000 Keyboard Replacement: paso 4, imagen 3 de 3
    • Grasp the inside edge of the battery.
    • Lift the inside edge of the battery up to detach the battery from the laptop.
  5. HP Pavilion dv1000 Keyboard Replacement, Keyboard: paso 5, imagen 1 de 1
    • Remove the highlighted screws.
    • After removing the screws, flip the laptop over.
  6. HP Pavilion dv1000 Keyboard Replacement: paso 6, imagen 1 de 2 HP Pavilion dv1000 Keyboard Replacement: paso 6, imagen 2 de 2
    • Open the laptop.
    • Use the spudger to lift the keyboard.
    • Do not pull the keyboard up and away from the computer, because it is still attached by a ribbon cable.
    • Press the two white clips forward with your fingers and gently pull the ribbon from the clips.
Conclusión
Una persona más ha completado esta guía.
Tyler Latour
Miembro Desde 03/12/14
266 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 1,619
