Introducción
This guide will show you how to remove the heat sink.
Partes
No se requieren partes.
Shut down the computer.
Disconnect all external devices and cables from the computer.
Locate the small panel below the panel you just removed.
Loosen the one screw in the middle with a #00 Phillips screwdriver. Again, the screw will not fall out of the panel when loosened.
Lift the panel up and out of its slot to remove.
Remove and set aside all of the highlighted screws in the first picture with a #00 Phillips screwdriver.
Remove and separately set aside all of the highlighted screws in the second picture with a #00 Phillips screwdriver.
After removing the fan, locate the heat sink. The heat sink is the silver box above where the fan used to be.
Remove the two highlighted screws with a #00 Phillips screwdriver.
3 personas más completaron esta guía.
