Saltar al contenido principal
HP Pavilion dm4-1265dx Wi-Fi Card Replacement
Qué necesitas
  1. HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop over so the bottom is facing up.
  2. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: paso 2, imagen 1 de 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: paso 2, imagen 2 de 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: paso 2, imagen 3 de 3
    • Push the sliding lock to release the battery.
    • Remove the battery by lifting it away from the device.
  3. HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Back Panel: paso 3, imagen 1 de 2 HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Back Panel: paso 3, imagen 2 de 2
    • Orient the device so that the empty battery port is closest to you.
    • Loosen the two captive screws holding the back panel in place using a Phillips #0 screwdriver.
  4. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: paso 4, imagen 1 de 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: paso 4, imagen 2 de 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: paso 4, imagen 3 de 3
    • Pull back and lift the back panel to remove it from the device.
  5. HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Wi-Fi Card: paso 5, imagen 1 de 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Wi-Fi Card: paso 5, imagen 2 de 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Wi-Fi Card: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Using ESD safe tweezers, gently disconnect the black and white wires connecting the Wi-Fi card to the device.
    • Move the wires out of the way to allow the Wi-Fi card to spring up without obstructions.
  6. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: paso 6, imagen 1 de 2 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: paso 6, imagen 2 de 2
    • Remove the two 3.0 mm screws from the Wi-Fi card using a Phillips #0 screwdriver.
  7. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: paso 7, imagen 1 de 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: paso 7, imagen 2 de 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: paso 7, imagen 3 de 3
    • The Wi-Fi card will spring upwards.
    • Gently remove the Wi-Fi card by pulling it away from its socket.
Conclusión
Mason Hall
Miembro Desde 03/24/22
231 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 237
