Saltar al contenido principal
HP Pavilion dm4-1265dx Hard Drive Replacement
Qué necesitas
  1. HP Pavilion dm4-1265dx Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop over so the bottom is facing up.
  2. HP Pavilion dm4-1265dx Hard Drive Replacement: paso 2, imagen 1 de 3 HP Pavilion dm4-1265dx Hard Drive Replacement: paso 2, imagen 2 de 3 HP Pavilion dm4-1265dx Hard Drive Replacement: paso 2, imagen 3 de 3
    • Push the sliding lock to release the battery.
    • Remove the battery by lifting it away from the device.
  3. HP Pavilion dm4-1265dx Hard Drive Replacement, Back Panel: paso 3, imagen 1 de 2 HP Pavilion dm4-1265dx Hard Drive Replacement, Back Panel: paso 3, imagen 2 de 2
    • Orient the device so that the empty battery port is closest to you.
    • Loosen the two captive screws holding the back panel in place using a Phillips #0 screwdriver.
  4. HP Pavilion dm4-1265dx Hard Drive Replacement: paso 4, imagen 1 de 3 HP Pavilion dm4-1265dx Hard Drive Replacement: paso 4, imagen 2 de 3 HP Pavilion dm4-1265dx Hard Drive Replacement: paso 4, imagen 3 de 3
    • Pull back and lift the back panel to remove it from the device.
  5. HP Pavilion dm4-1265dx Hard Drive Replacement, Hard Drive: paso 5, imagen 1 de 3 HP Pavilion dm4-1265dx Hard Drive Replacement, Hard Drive: paso 5, imagen 2 de 3 HP Pavilion dm4-1265dx Hard Drive Replacement, Hard Drive: paso 5, imagen 3 de 3
    • Loosen the single captive screw holding the hard drive cover in place using a Phillips #0 screwdriver.
    • Lift the hard drive cover away and up to remove.
  6. HP Pavilion dm4-1265dx Hard Drive Replacement: paso 6, imagen 1 de 3 HP Pavilion dm4-1265dx Hard Drive Replacement: paso 6, imagen 2 de 3 HP Pavilion dm4-1265dx Hard Drive Replacement: paso 6, imagen 3 de 3
    • Lift the hard drive out of the device from the connector side.
    • Grasp the connector and pull it out of the hard drive.
    • Remove the hard drive from the laptop.
Conclusión
Matthew Walter
Miembro Desde 03/29/22
109 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 364
