Saltar al contenido principal
HP Pavilion dm4-1265dx Clock Battery Replacement
Qué necesitas
  1. HP Pavilion dm4-1265dx Clock Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop over so the bottom is facing up.
  2. HP Pavilion dm4-1265dx Clock Battery Replacement: paso 2, imagen 1 de 3 HP Pavilion dm4-1265dx Clock Battery Replacement: paso 2, imagen 2 de 3 HP Pavilion dm4-1265dx Clock Battery Replacement: paso 2, imagen 3 de 3
    • Push the sliding lock to release the battery.
    • Remove the battery by lifting it away from the device.
  3. HP Pavilion dm4-1265dx Clock Battery Replacement, Back Panel: paso 3, imagen 1 de 2 HP Pavilion dm4-1265dx Clock Battery Replacement, Back Panel: paso 3, imagen 2 de 2
    • Orient the device so that the empty battery port is closest to you.
    • Loosen the two captive screws holding the back panel in place using a Phillips #0 screwdriver.
  4. HP Pavilion dm4-1265dx Clock Battery Replacement: paso 4, imagen 1 de 3 HP Pavilion dm4-1265dx Clock Battery Replacement: paso 4, imagen 2 de 3 HP Pavilion dm4-1265dx Clock Battery Replacement: paso 4, imagen 3 de 3
    • Pull back and lift the back panel to remove it from the device.
  5. HP Pavilion dm4-1265dx Clock Battery Replacement, Clock Battery: paso 5, imagen 1 de 3 HP Pavilion dm4-1265dx Clock Battery Replacement, Clock Battery: paso 5, imagen 2 de 3 HP Pavilion dm4-1265dx Clock Battery Replacement, Clock Battery: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • The clock battery is a metallic disk near the battery port. The words "Lithium 3V" are on the face.
    • Disconnect the battery from the metallic fasteners using the tweezers.
    • Slightly bend the fasteners away from the battery.
    • Pick up the battery with the tweezers and dislodge from the fasteners.
  6. HP Pavilion dm4-1265dx Clock Battery Replacement: paso 6, imagen 1 de 1
    • Fully remove battery from the laptop.
Conclusión
Una persona más ha completado esta guía.
Isaiah Timbers
Miembro Desde 03/29/22
171 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 22
Todo El Tiempo: 376
