Saltar al contenido principal
HP Pavilion ZD7000 Wi-Fi Card Replacement
Qué necesitas
  1. HP Pavilion ZD7000 Wi-Fi Card Replacement, Battery: paso 1, imagen 1 de 1
    • Begin by turning the laptop over so that you can see the bottom of the computer.
  2. HP Pavilion ZD7000 Wi-Fi Card Replacement: paso 2, imagen 1 de 1
    • Slide the battery release switch to the right while simultaneously lifting up the battery.
  3. HP Pavilion ZD7000 Wi-Fi Card Replacement, Wi-Fi Card: paso 3, imagen 1 de 2 HP Pavilion ZD7000 Wi-Fi Card Replacement, Wi-Fi Card: paso 3, imagen 2 de 2
    • Unscrew the 2 screws from the plate that cover the Wi-Fi card.
    • Remove the cover.
  4. HP Pavilion ZD7000 Wi-Fi Card Replacement: paso 4, imagen 1 de 2 HP Pavilion ZD7000 Wi-Fi Card Replacement: paso 4, imagen 2 de 2
    • Disconnect these 2 antenna wires (which eventually connect to the monitor) from the Wi-Fi card.
    • For reassembly, note where the black and white cables connect to the card.
    • Release the Wi-Fi card from the laptop by pressing the metal hinges on either end of it.
    • Gently remove the card from laptop.
Conclusión
3 personas más completaron esta guía.
Shantel
Miembro Desde 04/20/10
545 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 30-37, Garner Spring 2010 Miembro de Cal Poly, Team 30-37, Garner Spring 2010
CPSU-GARNER-S10S30G37
4 Miembros
9 Guías creadas
2 comentarios
Can you upgrade the wifi card?
danoco - Contestar
is there a replacement I can buy
Braeden Culp - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 5,483
