Introducción
This guide will explain how to reach and remove your laptop's motherboard. The motherboard is hidden beneath several other components that will all need to be removed.
It is very important to keep track of everything you remove from the device, especially the screws, as losing or damaging pieces may cause even greater damage to the device. A recommended strategy is to place each component and its screws in a separate, labeled container.
Qué necesitas
Begin by turning the laptop over so that you can see the bottom of the computer.
Begin after removing the battery and fans.
Remove the screws from the outer frame of the laptop.
Remove screws from the battery area, noting the following:
These screws are on oversize clearing holes, but hold other components on the keyboard. It is not recommended to remove them yet.
Two screws secure the optical drive: one in the battery compartment and one in the RAM compartment.
With the screws removed, PUSH the optical drive out through the opening at the BLUE arrow. You will need to remove the drive to access two more screws at the edge of the frame in the opening of the optical drive.
Remove the screws holding the keyboard to the chassis.
Unplug the wire just below the right screw shown and the small white connector to the left of that screw.
11 personas más completaron esta guía.
4Guía Comentarios
this guid is perfect for a new bee to disassemble a laptop.forget about grammer and bullets points.follow the images it is great
Very helpful guide, thanks a lot.
