Saltar al contenido principal
HP Pavilion Touchsmart 11z-e000 WLAN Card Replacement
Qué necesitas
  1. HP Pavilion Touchsmart 11z-e000 WLAN Card Replacement, Battery: paso 1, imagen 1 de 1
    • Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
  2. HP Pavilion Touchsmart 11z-e000 WLAN Card Replacement, Remove back plate: paso 2, imagen 1 de 1
    • Using a spudger, pry the plastic plate off of the base of the computer.
  3. HP Pavilion Touchsmart 11z-e000 WLAN Card Replacement, Remove screws: paso 3, imagen 1 de 1
    • Remove the screws from the WLAN card
  4. HP Pavilion Touchsmart 11z-e000 WLAN Card Replacement, Remove WLAN card: paso 4, imagen 1 de 1
    • Remove the card by sliding out of the slot.
  5. HP Pavilion Touchsmart 11z-e000 WLAN Card Replacement, Disconnect the cables: paso 5, imagen 1 de 1
    • Remove the cables from their connections by pulling them off. They should snap on and off.
Conclusión
Nguyen
Miembro Desde 01/22/15
295 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 21-22, Maness Winter 2015 Miembro de Cal Poly, Team 21-22, Maness Winter 2015
CPSU-MANESS-W15S21G22
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 428
