Saltar al contenido principal
HP Pavilion Touchsmart 11z-e000 Hard Drive Replacement
Qué necesitas
  1. HP Pavilion Touchsmart 11z-e000 Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
  2. HP Pavilion Touchsmart 11z-e000 Hard Drive Replacement, Hard Drive: paso 2, imagen 1 de 1
    • Wedge your finger (or tool) in between the outer plastic cover of the laptop and the main part of the laptop.
    • Pry the outer plastic cover off of the laptop.
    • Prying the outer plastic cover off may take a significant amount of force.
  3. HP Pavilion Touchsmart 11z-e000 Hard Drive Replacement: paso 3, imagen 1 de 2 HP Pavilion Touchsmart 11z-e000 Hard Drive Replacement: paso 3, imagen 2 de 2
    • Unscrew all screws that surround the hard drive with a Philip Head
  4. HP Pavilion Touchsmart 11z-e000 Hard Drive Replacement: paso 4, imagen 1 de 2 HP Pavilion Touchsmart 11z-e000 Hard Drive Replacement: paso 4, imagen 2 de 2
    • Carefully lift the hard drive up by holding the tag shown here.
  5. HP Pavilion Touchsmart 11z-e000 Hard Drive Replacement: paso 5, imagen 1 de 1
    • Remove the final attachment to the hard drive located at the end shown here.
Conclusión
4 personas más completaron esta guía.
Robert Hemphill
Miembro Desde 01/22/15
269 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 21-22, Maness Winter 2015 Miembro de Cal Poly, Team 21-22, Maness Winter 2015
CPSU-MANESS-W15S21G22
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 10
Todo El Tiempo: 2,942
