Saltar al contenido principal
HP Pavilion Touchsmart 11z-e000 Fan Replacement
Qué necesitas
  1. HP Pavilion Touchsmart 11z-e000 Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
  2. HP Pavilion Touchsmart 11z-e000 Fan Replacement, Fan: paso 2, imagen 1 de 1
    • Slide a spudger under the outer plastic cover of the laptop.
    • Pry the outer plastic cover off of the laptop, one side at a time.
    • Prying the outer plastic cover off may take a significant amount of force.
  3. HP Pavilion Touchsmart 11z-e000 Fan Replacement: paso 3, imagen 1 de 1
    • Unscrew all screws attaching the fan to the metal backboard.
  4. HP Pavilion Touchsmart 11z-e000 Fan Replacement: paso 4, imagen 1 de 1
    • Turn the laptop over.
    • Slide a spudger in between the outer plastic cover of the keyboard and the main body of the laptop.
    • Pry the top plastic cover off of the laptop.
    • Prying the outer plastic cover off may take a significant amount of force. Be careful!
  5. HP Pavilion Touchsmart 11z-e000 Fan Replacement: paso 5, imagen 1 de 1
    • Unscrew the two screws that keep the fan in place.
  6. HP Pavilion Touchsmart 11z-e000 Fan Replacement: paso 6, imagen 1 de 1
    • Unplug the fan from the circuit board as shown
    • Carefully peel the tape connecting the fan and pull out the fan from the laptop.
Conclusión
Nguyen
Miembro Desde 01/22/15
295 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 21-22, Maness Winter 2015 Miembro de Cal Poly, Team 21-22, Maness Winter 2015
CPSU-MANESS-W15S21G22
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 1,038
