Saltar al contenido principal
HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement
Qué necesitas
  1. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Remove the battery from the device and unplug it.
    • Keep different sized screws separated from each other during disassembly and reassembly.
  2. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Using a Phillips #0 screwdriver, remove the two screws on the small back cover.
    • Remove the cover.
    • Remove the three screws that have been uncovered.
  3. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: paso 3, imagen 1 de 1
    • Remove the two rubber screw covers by the rubber feet of the device.
    • Using a Phillips #0 screwdriver, remove the two screws that have been uncovered.
  4. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: paso 4, imagen 1 de 1
    • Using a Phillips #0 screwdriver, remove the eight screws as directed.
    • Using a Phillips #1 screwdriver, remove the two remaining screws.
  5. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: paso 5, imagen 1 de 2 HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: paso 5, imagen 2 de 2
    • Using the plastic opening tool, gently pull up the keyboard starting from the bottom left corner, working your way to the bottom right corner.
    • To remove the keyboard, lift up the plastic retaining tab with the opening tool and gently pull out the ribbon wire.
  6. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: paso 6, imagen 1 de 1
    • Remove the plastic cover of the laptop using the opening tool.
    • The plastic cover is fragile, be cautious during removal.
  7. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: paso 7, imagen 1 de 1
    • Using the plastic opening tool, pull up the retaining tab and and pull out the ribbon wire
    • This port is fragile, take care in removing and reinserting the ribbon wire.
  8. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: paso 8, imagen 1 de 1
    • Using a Phillips #0 screwdriver, remove the six screws on the hard drive, then remove it.
    • Be sure to properly dispose or recycle your hard drive.
Conclusión
Justin Hurley
Miembro Desde 01/14/19
1 Reputación
1 Guía escrita
Equipo
IUPUI, Team S6-G6, Wilson Spring 2019 Miembro de IUPUI, Team S6-G6, Wilson Spring 2019
IUPUI-WILSON-S19S6G6
3 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 354
