Saltar al contenido principal
HP Pavilion Sleekbook 15- b000 Fan
Qué necesitas
  1. HP Pavilion Sleekbook 15- b000 Fan, Battery: paso 1, imagen 1 de 1
    • Unplug laptop from adapter and all other devices.
  2. HP Pavilion Sleekbook 15- b000 Fan: paso 2, imagen 1 de 1
    • Flip the laptop over with battery facing you.
  3. HP Pavilion Sleekbook 15- b000 Fan: paso 3, imagen 1 de 2 HP Pavilion Sleekbook 15- b000 Fan: paso 3, imagen 2 de 2
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. HP Pavilion Sleekbook 15- b000 Fan: paso 4, imagen 1 de 1
    • Pull battery out.
  5. HP Pavilion Sleekbook 15- b000 Fan, Keyboard: paso 5, imagen 1 de 1
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. HP Pavilion Sleekbook 15- b000 Fan: paso 6, imagen 1 de 1
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  7. HP Pavilion Sleekbook 15- b000 Fan: paso 7, imagen 1 de 1
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  8. HP Pavilion Sleekbook 15- b000 Fan: paso 8, imagen 1 de 1
    • Remove keyboard wire by popping latch under blue plastic
  9. HP Pavilion Sleekbook 15- b000 Fan, Case: paso 9, imagen 1 de 1
    • Using the spudger to lift up on the white tabs
    • Pull horizontally on the blue ribbon to disconnect the cables
  10. HP Pavilion Sleekbook 15- b000 Fan: paso 10, imagen 1 de 1
    • Remove the five 5.5mm Phillips #1 screws from the case
  11. HP Pavilion Sleekbook 15- b000 Fan: paso 11, imagen 1 de 1
    • Remove eight 6.5mm Phillips #1 screws from the back cover
  12. HP Pavilion Sleekbook 15- b000 Fan: paso 12, imagen 1 de 3 HP Pavilion Sleekbook 15- b000 Fan: paso 12, imagen 2 de 3 HP Pavilion Sleekbook 15- b000 Fan: paso 12, imagen 3 de 3
    • Starting at a top corner, use the pry tool to split the case.
    • Slowly work around the case, pulling up gently to release the clips.
  13. HP Pavilion Sleekbook 15- b000 Fan, Fan: paso 13, imagen 1 de 1
    • Remove the three x 5.5 mm restraining screws.
  14. HP Pavilion Sleekbook 15- b000 Fan: paso 14, imagen 1 de 1
    • Pull fan of of heat pipe.
  15. HP Pavilion Sleekbook 15- b000 Fan: paso 15, imagen 1 de 1
    • Remove fan.
Conclusión
Sam Barkley
Miembro Desde 02/13/18
983 Reputación
8 Guías creadas
Equipo
USF Tampa, Team S11-G2, Cheng Spring 2018 Miembro de USF Tampa, Team S11-G2, Cheng Spring 2018
USFT-CHENG-S18S11G2
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 367
