Saltar al contenido principal
HP Pavilion Sleekbook 14-b013cl Keyboard Replacement
Qué necesitas
  1. HP Pavilion Sleekbook 14-b013cl Keyboard Replacement, Battery: paso 1, imagen 1 de 2 HP Pavilion Sleekbook 14-b013cl Keyboard Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
  2. HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: paso 2, imagen 1 de 2 HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: paso 2, imagen 2 de 2
    • Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
  3. HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: paso 3, imagen 1 de 2 HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: paso 3, imagen 2 de 2
    • Carefully pull the battery away from the device.
  4. HP Pavilion Sleekbook 14-b013cl Keyboard Replacement, Keyboard: paso 4, imagen 1 de 1
    • Using the Phillips #0 screwdriver, remove the two screws.
  5. HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: paso 5, imagen 1 de 3 HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: paso 5, imagen 2 de 3 HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: paso 5, imagen 3 de 3
    • Use a plastic opening tool to pry up one of the upper counters on the keyboard
    • Run the tool along the upper edge of the keyboard and towards the opposite corner to release the latches.
  6. HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: paso 6, imagen 1 de 3 HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: paso 6, imagen 2 de 3 HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: paso 6, imagen 3 de 3
    • Push the button to release the connector and pull it out and remove the keyboard
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 499
