Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement
Qué necesitas
  1. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement, Battery: paso 1, imagen 1 de 2 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
    Pregunta a FixBot
    Agregar Comentario
  2. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: paso 2, imagen 1 de 2 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: paso 2, imagen 2 de 2
    • Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
    Pregunta a FixBot
    Agregar Comentario
  3. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: paso 3, imagen 1 de 2 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: paso 3, imagen 2 de 2
    • Carefully pull the battery away from the device.
    Pregunta a FixBot
    Agregar Comentario
  4. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement, Cooling Fan: paso 4, imagen 1 de 1
    • Using a Phillips #0 screwdriver, unscrew all nine of the screws from the bottom of the computer.
    • There is a wire connecting the keyboard to the motherboard. Do not pull the keyboard away until you have disconnected the wire.
    Pregunta a FixBot
    Agregar Comentario
  5. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: paso 5, imagen 1 de 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: paso 5, imagen 2 de 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: paso 5, imagen 3 de 3
    • Using a plastic opening tool, pry up along the edge of the keyboard.
    • There is a wire connecting the keyboard to the motherboard. Do not completely pull the keyboard off until the wire is disconnected.
    Pregunta a FixBot
    Agregar Comentario
  6. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: paso 6, imagen 1 de 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: paso 6, imagen 2 de 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: paso 6, imagen 3 de 3
    • To disconnect the wire, pry up on the latch connecting it to the motherboard.
    Pregunta a FixBot
    Agregar Comentario
  7. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: paso 7, imagen 1 de 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: paso 7, imagen 2 de 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: paso 7, imagen 3 de 3
    • Using a plastic or metal spudger, carefully pry apart the palm rest from the rest of the laptop.
    • Be careful when using the metal spudger, as you could damage the internal components if the spudger is inserted too far.
    • Do not completely pull the halves apart yet because there are still wires holding them together.
    Pregunta a FixBot
    Agregar Comentario
  8. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: paso 8, imagen 1 de 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: paso 8, imagen 2 de 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: paso 8, imagen 3 de 3
    • Disconnect the touch pad wire by flipping the black lever with a plastic spudger.
    Pregunta a FixBot
    Agregar Comentario
  9. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: paso 9, imagen 1 de 2 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: paso 9, imagen 2 de 2
    • Unscrew the circuit board underneath the power button.
    • Remove this circuit board by pulling up and away on the plastic tab.
    Pregunta a FixBot
    Agregar Comentario
  10. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: paso 10, imagen 1 de 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: paso 10, imagen 2 de 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: paso 10, imagen 3 de 3
    • Using a Phillips #0 screwdriver, remove all the screws and take the metal plate off the mother board.
    • Double sided tape holds the plate down as well as the screws. You will need to apply force to remove the plate.
    Pregunta a FixBot
    Agregar Comentario
  11. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: paso 11, imagen 1 de 2 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: paso 11, imagen 2 de 2
    • Remove the three screws holding the cooling fan in place using a Phillips #0 screwdriver.
    • Using a plastic opening tool, remove the power cable for the fan.
    • Remove the fan from the device.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Josh Svik
Miembro Desde 04/10/18
281 Reputación
1 Guía escrita
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 40
Todo El Tiempo: 739
