Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
HP Pavilion Sleekbook 14-b013cl Battery Replacement
  1. HP Pavilion Sleekbook 14-b013cl Battery Replacement, Battery: paso 1, imagen 1 de 2 HP Pavilion Sleekbook 14-b013cl Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
  2. HP Pavilion Sleekbook 14-b013cl Battery Replacement: paso 2, imagen 1 de 2 HP Pavilion Sleekbook 14-b013cl Battery Replacement: paso 2, imagen 2 de 2
    • Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
  3. HP Pavilion Sleekbook 14-b013cl Battery Replacement: paso 3, imagen 1 de 2 HP Pavilion Sleekbook 14-b013cl Battery Replacement: paso 3, imagen 2 de 2
    • Carefully pull the battery away from the device.
Conclusión
Place your new battery into the slot you just removed the old battery out of, and follow the steps in reverse order to accomplish this.
Una persona más ha completado esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 697
