Saltar al contenido principal
HP Pavilion Notebook 15-ab293cl Hard Drive Replacement
Qué necesitas
  1. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 2 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement, Hard Drive: paso 1, imagen 2 de 2
    • Flip the laptop over so that the battery is facing upward.
  2. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: paso 2, imagen 1 de 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: paso 2, imagen 2 de 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: paso 2, imagen 3 de 3
    • Slide both tab buttons inward to open the battery cover. Gently push the battery out to remove.
  3. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: paso 3, imagen 1 de 2 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: paso 3, imagen 2 de 2
    • Remove the black plastic hinge covers at the top corners of the laptop.
    • Use the Phillips #1 to remove the two 7.5mm screws.
    • Use the opening tool to pry the black covers off of the laptop.
  4. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: paso 4, imagen 1 de 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: paso 4, imagen 2 de 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: paso 4, imagen 3 de 3
    • Remember to remove the tabs shown in the second picture.
    • Remove all 16 - 7.5mm screws with the Phillips #1 screwdriver.
    • Pry and slide the CD/DVD drive out of the laptop case.
  5. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: paso 5, imagen 1 de 1
    • Unscrew the two 3.5mm silver screws with the Phillips #000 and the Philips # 1.
  6. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: paso 6, imagen 1 de 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: paso 6, imagen 2 de 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: paso 6, imagen 3 de 3
    • Turn the computer so that the screen faces you.
    • Use the pry tool to pry off the edge of the keyboard side of laptop.
  7. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: paso 7, imagen 1 de 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: paso 7, imagen 2 de 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: paso 7, imagen 3 de 3
    • The hard drive is located in the bottom corner of the laptop.
    • Gently lift up the hard drive and pry off the white tab to release the hard drive.
  8. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: paso 8, imagen 1 de 2 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: paso 8, imagen 2 de 2
    • Once you release the white tab from the green board, remove the hard drive.
Conclusión
Una persona más ha completado esta guía.
Efren Solis
Miembro Desde 09/10/18
228 Reputación
1 Guía escrita
Equipo
Gateway, Team S1-G2, Luster Fall 2018 Miembro de Gateway, Team S1-G2, Luster Fall 2018
GCC-LUSTER-F18S1G2
Miembros de 4
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 32
Ultimos 30 días: 66
Todo El Tiempo: 2,773
