Saltar al contenido principal
HP Pavilion N3350 Screen Assembly Replacement
Qué necesitas
  1. HP Pavilion N3350 Screen Assembly Replacement, Screen Assembly: paso 1, imagen 1 de 2 HP Pavilion N3350 Screen Assembly Replacement, Screen Assembly: paso 1, imagen 2 de 2
    • Open your laptop. Beneath the screen, there is a large plastic piece that contains slots for a speaker, the power button, and numerous indicator lights.
    • To remove this, pry it open with a spudger tool gently. It should pop out of place.
  2. HP Pavilion N3350 Screen Assembly Replacement: paso 2, imagen 1 de 2 HP Pavilion N3350 Screen Assembly Replacement: paso 2, imagen 2 de 2
    • Gently use a spudger tool or your fingers to disconnect the LCD cable from the screen.
    • This is one of three connectors that needs to be undone to disconnect the screen from the laptop.
  3. HP Pavilion N3350 Screen Assembly Replacement: paso 3, imagen 1 de 3 HP Pavilion N3350 Screen Assembly Replacement: paso 3, imagen 2 de 3 HP Pavilion N3350 Screen Assembly Replacement: paso 3, imagen 3 de 3
    • Remove the 1 cm screw with a Phillips #1 screwdriver to allow the screen and top of the laptop to be separated from the keyboard and bottom.
    • Lift the entire top away from the bottom, and set bottom half of the laptop aside.
  4. HP Pavilion N3350 Screen Assembly Replacement: paso 4, imagen 1 de 3 HP Pavilion N3350 Screen Assembly Replacement: paso 4, imagen 2 de 3 HP Pavilion N3350 Screen Assembly Replacement: paso 4, imagen 3 de 3
    • Remove the 6 rubber screw caps with a metal spudger.
    • After removing the 6 rubber screw caps, use a Phillips #1 screwdriver to unscrew the six 6mm screws.
  5. HP Pavilion N3350 Screen Assembly Replacement: paso 5, imagen 1 de 2 HP Pavilion N3350 Screen Assembly Replacement: paso 5, imagen 2 de 2
    • To separate the plastic cover, use a plastic opening tool to undo each plastic connecting clip between the two.
    • You can find the plastic connecting clips by sliding the plastic opening tool along the seam between the two plastic covers.
    • Remove the top plastic cover once all connections have been released.
  6. HP Pavilion N3350 Screen Assembly Replacement: paso 6, imagen 1 de 3 HP Pavilion N3350 Screen Assembly Replacement: paso 6, imagen 2 de 3 HP Pavilion N3350 Screen Assembly Replacement: paso 6, imagen 3 de 3
    • Disconnect the connectors using a plastic opening tool.
    • Once these two connectors are released, the screen should be electronically freed from the rest of the laptop.
  7. HP Pavilion N3350 Screen Assembly Replacement: paso 7, imagen 1 de 1
    • At each corner, there is a 1 centimeter silver screw connecting the screen frame to the laptop. Remove these using a Phillips #1 Screwdriver.
  8. HP Pavilion N3350 Screen Assembly Replacement: paso 8, imagen 1 de 3 HP Pavilion N3350 Screen Assembly Replacement: paso 8, imagen 2 de 3 HP Pavilion N3350 Screen Assembly Replacement: paso 8, imagen 3 de 3
    • There should be thin piece of copper 'tape' holding the LCD cable down. Remove this gently with tweezers.
    • Remove the screen from the device.
Conclusión
Una persona más ha completado esta guía.
Emily Hatstat
Miembro Desde 03/19/18
481 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 167
