Saltar al contenido principal
HP Pavilion N3350 RAM Replacement
Qué necesitas
  1. HP Pavilion N3350 RAM Replacement, RAM: paso 1, imagen 1 de 1
    • Locate the RAM on the bottom side of the laptop, the cover is secured by a 6 millimeter screw. Remove this with a Philips #1 screwdriver.
  2. HP Pavilion N3350 RAM Replacement: paso 2, imagen 1 de 1
    • Underneath are the RAM boards. They are secured by two plastic clips each. Locate these to continue removal.
  3. HP Pavilion N3350 RAM Replacement: paso 3, imagen 1 de 1
    • Place your thumbs on two of the clips securing one board. Push outwards on the clips. This should pop the board up.
  4. HP Pavilion N3350 RAM Replacement: paso 4, imagen 1 de 1
    • Repeat on second board. When both are released, they should appear as they do in the picture.
  5. HP Pavilion N3350 RAM Replacement: paso 5, imagen 1 de 1
    • The RAM should be easily removed once released from the plastic clips.
Conclusión
2 personas más completaron esta guía.
Equipo
Un comentario
Windows 98 Product Key?
Dudefoxlive - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 130
