Saltar al contenido principal
HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement
Qué necesitas
  1. HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement, RAM: paso 1, imagen 1 de 1
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: paso 2, imagen 1 de 2 HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: paso 2, imagen 2 de 2
    • Using the 1.5 Phillips #1 screwdriver, loosen the 7 screws.
  3. HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: paso 3, imagen 1 de 3 HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: paso 3, imagen 2 de 3 HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: paso 3, imagen 3 de 3
    • Insert the metal opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case.
    • Remove the back case.
    • When removing the back plate, use caution, removing slowly in order to not break the clips.
  4. HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: paso 4, imagen 1 de 3 HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: paso 4, imagen 2 de 3 HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: paso 4, imagen 3 de 3
    • Using your fingers, pull the metal arms (located on both sides of the RAM stick) slightly away from it.
    • With your fingers, push on the Ram stick until the metal arms are not holding the stick.
    • The RAM will pop up by a few millimeters up.
    • Remove it by pulling straight towards you and not a angle so you don't damage the socket.
  5. HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: paso 5, imagen 1 de 2 HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: paso 5, imagen 2 de 2
    • Slide the RAM stick out from the memory module slot.
    • Repeat for the RAM stick located below. This computer had RAM in the slot below.
Conclusión
Una persona más ha completado esta guía.
Anthony Padilla
Miembro Desde 10/30/23
121 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 45
Todo El Tiempo: 166
