Saltar al contenido principal
HP Pavilion G7-2289wm RAM Replacement
Qué necesitas
  1. HP Pavilion G7-2289wm RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm RAM Replacement, RAM: paso 2, imagen 1 de 1
    • Loosen the screw that secures the service cover.
    • Pull the service cover towards you to remove it.
  3. HP Pavilion G7-2289wm RAM Replacement: paso 3, imagen 1 de 1
    • Unlock the tabs on each side of the ram module. (this lifts the ram module up)
  4. HP Pavilion G7-2289wm RAM Replacement: paso 4, imagen 1 de 1
    • Remove the ram module by pulling it gently away from the slot.
Conclusión
Ryson Smith
Miembro Desde 03/19/18
636 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 124
