Saltar al contenido principal
HP Pavilion G7-2289wm Keyboard Replacement
Qué necesitas
  1. HP Pavilion G7-2289wm Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Keyboard Replacement, Keyboard: paso 2, imagen 1 de 1
    • Remove all the screw that secures the keyboard to the computer using a Phillips #0 screwdriver.
  3. HP Pavilion G7-2289wm Keyboard Replacement: paso 3, imagen 1 de 3 HP Pavilion G7-2289wm Keyboard Replacement: paso 3, imagen 2 de 3 HP Pavilion G7-2289wm Keyboard Replacement: paso 3, imagen 3 de 3
    • Flip your laptop around to the front, using an opening tool, pry around the perimeter of the keyboard.
    • Lift the keyboard from the top backward towards the touch pad.
    • Unlatch the keyboard connector from the motherboard and remove the keyboard.
Conclusión
Ryson Smith
Miembro Desde 03/19/18
636 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 207
