Saltar al contenido principal
HP Pavilion G7-2289wm Hard Drive Replacement
Qué necesitas
  1. HP Pavilion G7-2289wm Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Hard Drive Replacement, Hard Drive: paso 2, imagen 1 de 1
    • Loosen the screw that secures the service cover using a Phillips #0 screwdriver.
    • Pull the edge of the service cover toward you to remove it.
  3. HP Pavilion G7-2289wm Hard Drive Replacement: paso 3, imagen 1 de 1
    • Disconnect the hard drive connector cable from the motherboard.
  4. HP Pavilion G7-2289wm Hard Drive Replacement: paso 4, imagen 1 de 1
    • Lift the front edge of the hard drive, then pull the hard drive out gently.
Conclusión
Ryson Smith
Miembro Desde 03/19/18
636 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 9
Todo El Tiempo: 192
