Saltar al contenido principal
HP Pavilion G7-2235DX Screen Replacement
Qué necesitas
  1. HP Pavilion G7-2235DX Screen Replacement, Fan: paso 1, imagen 1 de 1
    • Flip the laptop over and remove six 7.25mm screws.
  2. HP Pavilion G7-2235DX Screen Replacement: paso 2, imagen 1 de 2 HP Pavilion G7-2235DX Screen Replacement: paso 2, imagen 2 de 2
    • Using the plastic opening tool or spudger, separate the keyboard from the frame of the laptop.
    • Gently pull the keyboard away from the laptop, toward you, until it is completely separated from the laptop.
  3. HP Pavilion G7-2235DX Screen Replacement: paso 3, imagen 1 de 2 HP Pavilion G7-2235DX Screen Replacement: paso 3, imagen 2 de 2
    • Remove the four 7.25mm screws located by the red markers.
  4. HP Pavilion G7-2235DX Screen Replacement: paso 4, imagen 1 de 2 HP Pavilion G7-2235DX Screen Replacement: paso 4, imagen 2 de 2
    • Gently lift the panel up, exposing the inside of the laptop.
  5. HP Pavilion G7-2235DX Screen Replacement: paso 5, imagen 1 de 2 HP Pavilion G7-2235DX Screen Replacement: paso 5, imagen 2 de 2
    • The fan is located in the top, left hand corner. Now, it can be gently lifted out using your hands.
  6. HP Pavilion G7-2235DX Screen Replacement, Screen: paso 6, imagen 1 de 1
    • To remove the laptop's screen, you will have to remove a total of four 7.25mm screws.
    • First, remove the two 7.25mm screws found in the upper right corner as shown.
  7. HP Pavilion G7-2235DX Screen Replacement: paso 7, imagen 1 de 2 HP Pavilion G7-2235DX Screen Replacement: paso 7, imagen 2 de 2
    • Next, unscrew the two 7.25mm screws in the upper left corner of the laptop as shown.
  8. HP Pavilion G7-2235DX Screen Replacement: paso 8, imagen 1 de 2 HP Pavilion G7-2235DX Screen Replacement: paso 8, imagen 2 de 2
    • Once all of the screws have been removed, gently lift the laptop's screen from the base of the computer.
Conclusión
2 personas más completaron esta guía.
Equipo
USF Tampa, Team 1-7, Leahy Fall 2016 Miembro de USF Tampa, Team 1-7, Leahy Fall 2016
USFT-LEAHY-F16S1G7
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 480
