Introducción
The hard drive is a high-capacity storage device that is installed within the laptop. It permanently stores and recovers data from the laptop. Over time the hard drive can slow down the processing speed of the laptop. In order to fix this problem, the hard drive will need to be replaced. This guide will show how to properly replace the hard drive.
Qué necesitas
Turn your laptop over so the bottom is facing up.
Locate the battery latch and slide the latch switch all the way to the left.
Remove the two 5.5 mm JIS#0 screws from the hard drive cover.
Remove cover from the back of the laptop.
