Saltar al contenido principal
HP Pavilion G60-630US Hard Drive Replacement
Qué necesitas
  1. HP Pavilion G60-630US Hard Drive Replacement, Battery: paso 1, imagen 1 de 3 HP Pavilion G60-630US Hard Drive Replacement, Battery: paso 1, imagen 2 de 3 HP Pavilion G60-630US Hard Drive Replacement, Battery: paso 1, imagen 3 de 3
    • Make sure the laptop is powered off and unplugged first.
    • Turn your laptop over so the bottom is facing up.
    • Locate the battery latch and slide the latch switch all the way to the left.
    • The latch will lock and stay in place.
  2. HP Pavilion G60-630US Hard Drive Replacement: paso 2, imagen 1 de 3 HP Pavilion G60-630US Hard Drive Replacement: paso 2, imagen 2 de 3 HP Pavilion G60-630US Hard Drive Replacement: paso 2, imagen 3 de 3
    • Carefully lift the battery out and away from the laptop.
  3. HP Pavilion G60-630US Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 1
    • Remove the two 5.5 mm JIS#0 screws from the hard drive cover.
    • Remove cover from the back of the laptop.
  4. HP Pavilion G60-630US Hard Drive Replacement: paso 4, imagen 1 de 1
    • Remove three 5.5 mm JIS#0 screws.
  5. HP Pavilion G60-630US Hard Drive Replacement: paso 5, imagen 1 de 1
    • Gently, slide the whole hard drive to the right with your fingers.
  6. HP Pavilion G60-630US Hard Drive Replacement: paso 6, imagen 1 de 3 HP Pavilion G60-630US Hard Drive Replacement: paso 6, imagen 2 de 3 HP Pavilion G60-630US Hard Drive Replacement: paso 6, imagen 3 de 3
    • Lift up on black tap attached to the hard drive to remove the hard drive.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 720
