Saltar al contenido principal
HP Pavilion G60-630US Battery Replacement
  1. HP Pavilion G60-630US Battery Replacement, Battery: paso 1, imagen 1 de 3 HP Pavilion G60-630US Battery Replacement, Battery: paso 1, imagen 2 de 3 HP Pavilion G60-630US Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Make sure the laptop is powered off and unplugged first.
    • Turn your laptop over so the bottom is facing up.
    • Locate the battery latch and slide the latch switch all the way to the left.
    • The latch will lock and stay in place.
  2. HP Pavilion G60-630US Battery Replacement: paso 2, imagen 1 de 3 HP Pavilion G60-630US Battery Replacement: paso 2, imagen 2 de 3 HP Pavilion G60-630US Battery Replacement: paso 2, imagen 3 de 3
    • Carefully lift the battery out and away from the laptop.
Conclusión
To reassemble your device, line up the battery and place it gently on the metal prongs to ensure a stable connection.
[deleted]
Miembro Desde 10/02/17
213 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 446
