Saltar al contenido principal
HP Pavilion G60-247CL Screen Replacement
Qué necesitas
  1. HP Pavilion G60-247CL Screen Replacement, Battery: paso 1, imagen 1 de 3 HP Pavilion G60-247CL Screen Replacement, Battery: paso 1, imagen 2 de 3 HP Pavilion G60-247CL Screen Replacement, Battery: paso 1, imagen 3 de 3
    • Press down and to the right on the battery lock slide.
    • Once slid over to the right the battery will pop up and out.
  2. HP Pavilion G60-247CL Screen Replacement, Screen: paso 2, imagen 1 de 1
    • Remove the seven Phillips #1 screws from the back side of the laptop.
  3. HP Pavilion G60-247CL Screen Replacement: paso 3, imagen 1 de 2 HP Pavilion G60-247CL Screen Replacement: paso 3, imagen 2 de 2
    • Remove the seven Phillips #0 screws from the battery compartment.
  4. HP Pavilion G60-247CL Screen Replacement: paso 4, imagen 1 de 3 HP Pavilion G60-247CL Screen Replacement: paso 4, imagen 2 de 3 HP Pavilion G60-247CL Screen Replacement: paso 4, imagen 3 de 3
    • Turn the computer around to the front side.
    • Using an opening tool (Spudger), prop open the keyboard casing.
  5. HP Pavilion G60-247CL Screen Replacement: paso 5, imagen 1 de 3 HP Pavilion G60-247CL Screen Replacement: paso 5, imagen 2 de 3 HP Pavilion G60-247CL Screen Replacement: paso 5, imagen 3 de 3
    • Carefully lift up the keyboard.
    • Gently pull up the connecting wire clip (located in the middle) to completely detach the keyboard.
  6. HP Pavilion G60-247CL Screen Replacement: paso 6, imagen 1 de 3 HP Pavilion G60-247CL Screen Replacement: paso 6, imagen 2 de 3 HP Pavilion G60-247CL Screen Replacement: paso 6, imagen 3 de 3
    • At the top right of the laptop there will be another wire clip holding the keyboard casing.
    • Carefully pull out the wire clip to fully detach the covering.
  7. HP Pavilion G60-247CL Screen Replacement: paso 7, imagen 1 de 2 HP Pavilion G60-247CL Screen Replacement: paso 7, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • At the top right of the laptop remove the black wire from under the metal tabs using the tweezers.
  8. HP Pavilion G60-247CL Screen Replacement: paso 8, imagen 1 de 2 HP Pavilion G60-247CL Screen Replacement: paso 8, imagen 2 de 2
    • Remove the black wire from the top right corner by gently pulling outward.
  9. HP Pavilion G60-247CL Screen Replacement: paso 9, imagen 1 de 2 HP Pavilion G60-247CL Screen Replacement: paso 9, imagen 2 de 2
    • At the top left of the computer remove the black clip using the opening tool.
    • Push the opening tool to the right to pop out the clip.
  10. HP Pavilion G60-247CL Screen Replacement: paso 10, imagen 1 de 3 HP Pavilion G60-247CL Screen Replacement: paso 10, imagen 2 de 3 HP Pavilion G60-247CL Screen Replacement: paso 10, imagen 3 de 3
    • Locate at the bottom left of the computer a white clip.
    • Using an opening tool, prop out the white clip.
  11. HP Pavilion G60-247CL Screen Replacement: paso 11, imagen 1 de 2 HP Pavilion G60-247CL Screen Replacement: paso 11, imagen 2 de 2
    • On the left side of the computer locate the black wire with the clear clip.
    • Gently pull the wire to the right to detach it.
  12. HP Pavilion G60-247CL Screen Replacement: paso 12, imagen 1 de 3 HP Pavilion G60-247CL Screen Replacement: paso 12, imagen 2 de 3 HP Pavilion G60-247CL Screen Replacement: paso 12, imagen 3 de 3
    • At the top corners of the computer, unscrew the three Phillips #0 screws.
    • Lift up the top half of the computer carefully.
  13. HP Pavilion G60-247CL Screen Replacement: paso 13, imagen 1 de 3 HP Pavilion G60-247CL Screen Replacement: paso 13, imagen 2 de 3 HP Pavilion G60-247CL Screen Replacement: paso 13, imagen 3 de 3
    • Locate the two screws at the bottom corners of the screen.
    • Using the tweezers remove the rubber black covering over the screw.
    • Remove the two Phillips #0 screws.
  14. HP Pavilion G60-247CL Screen Replacement: paso 14, imagen 1 de 3 HP Pavilion G60-247CL Screen Replacement: paso 14, imagen 2 de 3 HP Pavilion G60-247CL Screen Replacement: paso 14, imagen 3 de 3
    • Using the opening tool, prop off the screen covering.
    • Remove the covering to expose the screen completely.
  15. HP Pavilion G60-247CL Screen Replacement: paso 15, imagen 1 de 3 HP Pavilion G60-247CL Screen Replacement: paso 15, imagen 2 de 3 HP Pavilion G60-247CL Screen Replacement: paso 15, imagen 3 de 3
    • Remove the bottom two screen bearings.
    • Using a Phillips 1 screwdriver, remove the two screws on each side.
  16. HP Pavilion G60-247CL Screen Replacement: paso 16, imagen 1 de 2 HP Pavilion G60-247CL Screen Replacement: paso 16, imagen 2 de 2
    • Using the tweezers remove the red and white wire from the bottom of the screen.
  17. HP Pavilion G60-247CL Screen Replacement: paso 17, imagen 1 de 2 HP Pavilion G60-247CL Screen Replacement: paso 17, imagen 2 de 2
    • Prop the screen up slightly .
    • Using the tweezers unclip the white wire.
  18. HP Pavilion G60-247CL Screen Replacement: paso 18, imagen 1 de 2 HP Pavilion G60-247CL Screen Replacement: paso 18, imagen 2 de 2
    • While the screen is still propped open remove the black wire from the bottom middle of the screen by pulling gently.
  19. HP Pavilion G60-247CL Screen Replacement: paso 19, imagen 1 de 1
    • Remove the screen from the outer casing carefully.
Conclusión
Haley Matthews
Miembro Desde 03/12/18
517 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 301
