Saltar al contenido principal
HP Pavilion G60-235DX Ram Replacement
Qué necesitas
  1. HP Pavilion G60-235DX Ram Replacement, Ram: paso 1, imagen 1 de 1
    • Lay the computer so that the backside is facing you and locate the screw in the picture.
  2. HP Pavilion G60-235DX Ram Replacement: paso 2, imagen 1 de 1
    • Remove the screws.
  3. HP Pavilion G60-235DX Ram Replacement: paso 3, imagen 1 de 1
    • Remove the cover that was held in by the screws that you just removed.
  4. HP Pavilion G60-235DX Ram Replacement: paso 4, imagen 1 de 1
    • Push this slide over in order to remove the battery. This is safe when working with your computers memory.
  5. HP Pavilion G60-235DX Ram Replacement: paso 5, imagen 1 de 1
    • Remove each one of the rams so that the computer looks like this. You can do so be squeezing tabs on each side of the ram.
Conclusión
James de Fremery
Miembro Desde 01/26/17
201 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 10-5, Banghart Winter 2017 Miembro de Cal Poly, Team 10-5, Banghart Winter 2017
CPSU-BANGHART-W17S10G5
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 186
