Saltar al contenido principal
HP Pavilion G60-235DX Keyboard Replacement
Qué necesitas
  1. HP Pavilion G60-235DX Keyboard  Replacement, Keyboard: paso 1, imagen 1 de 2 HP Pavilion G60-235DX Keyboard  Replacement, Keyboard: paso 1, imagen 2 de 2
    • Please turn the power of your device off. If not, it may cause a damage to the computer's hard drive and the person.
    • Slide the lock to remove the battery
    • After removing the battery, you can find 8 screws where battery were placed. Unscrew those 8 screws.
  2. HP Pavilion G60-235DX Keyboard  Replacement: paso 2, imagen 1 de 3 HP Pavilion G60-235DX Keyboard  Replacement: paso 2, imagen 2 de 3 HP Pavilion G60-235DX Keyboard  Replacement: paso 2, imagen 3 de 3
    • Do not force if the frame is not coming out. It may break the clip of the frame.
    • After the screws from battery house are removed, open the laptop to remove the keyboard frame.
    • Approach the frame on the side by using the prying tool. Carefully remove the clip. Watch out not to break the clip.
    • Then use the prying tool to carefully remove the frame from the top. Be careful not to break the clip.
    • Then, press the button located top of the touch pad to completely remove the frame from the bottom of the frame.
  3. HP Pavilion G60-235DX Keyboard  Replacement: paso 3, imagen 1 de 1
    • When the frame is removed, keyboard will be free to be removed. There is cable ribbon to be removed. Gently pull out the ribbon from where it is plugged.
    • The keyboard is now detached from the computer.
Conclusión
Gilbert Han
Miembro Desde 01/24/17
241 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 10-5, Banghart Winter 2017 Miembro de Cal Poly, Team 10-5, Banghart Winter 2017
CPSU-BANGHART-W17S10G5
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 465
