Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
HP Pavilion G6-1d16dx Wireless Card Replacement
Qué necesitas
    1. HP Pavilion G6-1d16dx Wireless Card Replacement, Battery: paso 1, imagen 1 de 1
      • Flip the computer so that the bottom side is facing up, and locate the battery above the screen hinges.
      Pregunta a FixBot
      Agregar Comentario
    2. HP Pavilion G6-1d16dx Wireless Card Replacement: paso 2, imagen 1 de 1
      • Slide the switch under the battery compartment to release the battery.
      Pregunta a FixBot
      Agregar Comentario
    3. HP Pavilion G6-1d16dx Wireless Card Replacement: paso 3, imagen 1 de 1
      • Remove the battery.
      • The battery will have popped out of the compartment when it was released.
      Pregunta a FixBot
      Agregar Comentario
    1. HP Pavilion G6-1d16dx Wireless Card Replacement, Wireless Card: paso 4, imagen 1 de 2 HP Pavilion G6-1d16dx Wireless Card Replacement, Wireless Card: paso 4, imagen 2 de 2
      • Unscrew the two captive screws using the Phillips #000 screwdriver.
      • The screws will not come all the way out; stop when you hear them click.
      • Unsnap the protective cover off of the device.
      • Locate the wireless card.
      Pregunta a FixBot
      Agregar Comentario
    2. HP Pavilion G6-1d16dx Wireless Card Replacement: paso 5, imagen 1 de 2 HP Pavilion G6-1d16dx Wireless Card Replacement: paso 5, imagen 2 de 2
      • Remove the two screws located on the corners of the wireless card, using the Phillips #000 screwdriver.
      • Slide the Wi-Fi card out of the socket.
      Pregunta a FixBot
      Agregar Comentario
    3. HP Pavilion G6-1d16dx Wireless Card Replacement: paso 6, imagen 1 de 1
      • Using your fingers, unsnap the coaxial cable wires from the wireless card.
      • Connect them to the new card based on the attachment points.
      • These points are indicated by numbered tabs. For example, wire #1 connects to #1 on the wireless card.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 37
Todo El Tiempo: 2,150
