Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
HP Pavilion G6-1d16dx Screen hinges Replacement
Qué necesitas
    1. HP Pavilion G6-1d16dx Screen hinges Replacement, Battery: paso 1, imagen 1 de 1
      • Flip the computer so that the bottom side is facing up, and locate the battery above the screen hinges.
      Pregunta a FixBot
      Agregar Comentario
    2. HP Pavilion G6-1d16dx Screen hinges Replacement: paso 2, imagen 1 de 1
      • Slide the switch under the battery compartment to release the battery.
      Pregunta a FixBot
      Agregar Comentario
    3. HP Pavilion G6-1d16dx Screen hinges Replacement: paso 3, imagen 1 de 1
      • Remove the battery.
      • The battery will have popped out of the compartment when it was released.
      Pregunta a FixBot
      Agregar Comentario
    1. HP Pavilion G6-1d16dx Screen hinges Replacement, Motherboard: paso 4, imagen 1 de 1
      • Unscrew the two silver screws holding the protective cover in place until they make a clicking noise.
      • The screws do not remove from the cover.
      Pregunta a FixBot
      Agregar Comentario
    2. HP Pavilion G6-1d16dx Screen hinges Replacement: paso 5, imagen 1 de 2 HP Pavilion G6-1d16dx Screen hinges Replacement: paso 5, imagen 2 de 2
      • Unsnap the Cover by lifting the edge along the battery compartment.
      • Remove all of the body screws.
      • Remove the rubber cap and the screw underneath it.
      Pregunta a FixBot
      Agregar Comentario
    3. HP Pavilion G6-1d16dx Screen hinges Replacement: paso 6, imagen 1 de 3 HP Pavilion G6-1d16dx Screen hinges Replacement: paso 6, imagen 2 de 3 HP Pavilion G6-1d16dx Screen hinges Replacement: paso 6, imagen 3 de 3
      • The keyboard is held in by nine tabs
      • Using a metal tool, depress the center tab and pry up the keyboard by pivoting the tool towards the screen.
      Pregunta a FixBot
      Agregar Comentario
    4. HP Pavilion G6-1d16dx Screen hinges Replacement: paso 7, imagen 1 de 2 HP Pavilion G6-1d16dx Screen hinges Replacement: paso 7, imagen 2 de 2
      • Slide the tool that is now under the keyboard sideways along the edge and use another tool to depress the other tabs along the edge of the keyboard.
      • As you depress the tabs, the edges of the keyboard will pop up.
      • Lift off the keyboard
      Pregunta a FixBot
      Agregar Comentario
    5. HP Pavilion G6-1d16dx Screen hinges Replacement: paso 8, imagen 1 de 1
      • Flip up the black tab holding the keyboard in place via the ribbon cable and pull out the cable
      Pregunta a FixBot
      Agregar Comentario
    6. HP Pavilion G6-1d16dx Screen hinges Replacement: paso 9, imagen 1 de 3 HP Pavilion G6-1d16dx Screen hinges Replacement: paso 9, imagen 2 de 3 HP Pavilion G6-1d16dx Screen hinges Replacement: paso 9, imagen 3 de 3
      • Remove the two remaining ribbon cables.
      • Remove the screws holding in the protective cover underneath the keyboard.
      • Pop the cover off using any flat metal tool, starting with where you took out the optical drive
      • It will be very sticky near the edge closest to the screen. This is where the sticker in the battery compartment is stuck to. just use a little more force.
      Pregunta a FixBot
      Agregar Comentario
    7. HP Pavilion G6-1d16dx Screen hinges Replacement: paso 10, imagen 1 de 1
      • Unplug the ribbon cable on the right side of the motherboard.
      Pregunta a FixBot
      Agregar Comentario
    8. HP Pavilion G6-1d16dx Screen hinges Replacement: paso 11, imagen 1 de 2 HP Pavilion G6-1d16dx Screen hinges Replacement: paso 11, imagen 2 de 2
      • Underneath the computer, unscrew the hard drive connector screw, and pop out the hard drive plug-in.
      Pregunta a FixBot
      Agregar Comentario
    9. HP Pavilion G6-1d16dx Screen hinges Replacement: paso 12, imagen 1 de 1
      • Unscrew all mother board screws and lift the motherboard out of the body.
      • For replacing the screen hinges and screen, skip this step
      Pregunta a FixBot
      Agregar Comentario
    1. HP Pavilion G6-1d16dx Screen hinges Replacement, Screen hinges: paso 13, imagen 1 de 1
      • Remove the five screws holding hinges to base.
      • Do not unscrew the motherboard screws
      Pregunta a FixBot
      Agregar Comentario
    2. HP Pavilion G6-1d16dx Screen hinges Replacement: paso 14, imagen 1 de 2 HP Pavilion G6-1d16dx Screen hinges Replacement: paso 14, imagen 2 de 2
      • Lift the tape tab up from the screen plug, and unplug the screen from the motherboard.
      • Unplug the wires from the wireless card and pull them through the body.
      Pregunta a FixBot
      Agregar Comentario
    3. HP Pavilion G6-1d16dx Screen hinges Replacement: paso 15, imagen 1 de 1
      • Remove the sticky tabs on the bottom of the screen just outside the hinges, and remove the two screws underneath.
      Pregunta a FixBot
      Agregar Comentario
    4. HP Pavilion G6-1d16dx Screen hinges Replacement: paso 16, imagen 1 de 1
      • Pry off the plastic surrounding the screen with any flat metal tool.
      Pregunta a FixBot
      Agregar Comentario
    5. HP Pavilion G6-1d16dx Screen hinges Replacement: paso 17, imagen 1 de 1
      • Remove the screws holding the hinge covers in place.
      • Remove the hinge covers.
      Pregunta a FixBot
      Agregar Comentario
    6. HP Pavilion G6-1d16dx Screen hinges Replacement: paso 18, imagen 1 de 1
      • Use a pair of pliers to unscrew the nut and pull out the hinge.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
2 personas más completaron esta guía.
1Guía Comentario
Not so good a manual. See my remarks.
This laptop is of extremely poor building quality. Disaster lures in every badly made detail.
Eveline Bernard - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 13
Ultimos 30 días: 47
Todo El Tiempo: 4,092
