Saltar al contenido principal
HP Pavilion G6-1d16dx Optical drive Replacement
Qué necesitas
  1. HP Pavilion G6-1d16dx Optical drive Replacement, Optical drive: paso 1, imagen 1 de 2 HP Pavilion G6-1d16dx Optical drive Replacement, Optical drive: paso 1, imagen 2 de 2
    • Unscrew screws holding the protective cover in place until they make a clicking noise.
    • Screws do not detach from protective cover.
    • Unsnap the cover by lifting the edge along the battery compartment.
  2. HP Pavilion G6-1d16dx Optical drive Replacement: paso 2, imagen 1 de 1
    • Use a PH0 screwdriver to remove the single screw holding in the optical drive.
  3. HP Pavilion G6-1d16dx Optical drive Replacement: paso 3, imagen 1 de 1
    • Slide out the optical drive.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 187
