Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
HP Pavilion G6 Screen Replacement
Qué necesitas
    1. HP Pavilion G6  Screen Replacement, Remove the battery: paso 1, imagen 1 de 3 HP Pavilion G6  Screen Replacement, Remove the battery: paso 1, imagen 2 de 3 HP Pavilion G6  Screen Replacement, Remove the battery: paso 1, imagen 3 de 3
      • Close the laptop and flip it over.
      • Slide the release pin to pop the battery.
      • Remove the battery completely.
      Pregunta a FixBot
      Agregar Comentario
    2. HP Pavilion G6  Screen Replacement, Remove the screw covers: paso 2, imagen 1 de 3 HP Pavilion G6  Screen Replacement, Remove the screw covers: paso 2, imagen 2 de 3 HP Pavilion G6  Screen Replacement, Remove the screw covers: paso 2, imagen 3 de 3
      Herramienta utilizada en este paso:
      • Open the laptop and locate the screw covers.
      • Remove the screw covers at the bottom of the screen with tweezers.
      • Keep them somewhere safe as you will need to stick them back after the repair.
      Pregunta a FixBot
      Agregar Comentario
    3. HP Pavilion G6  Screen Replacement, Remove the plastic frame: paso 3, imagen 1 de 3 HP Pavilion G6  Screen Replacement, Remove the plastic frame: paso 3, imagen 2 de 3 HP Pavilion G6  Screen Replacement, Remove the plastic frame: paso 3, imagen 3 de 3
      • Unscrew the exposed 2 x Philips screws and set them aside.
      • Starting from the top, pry up the plastic frame with your fingernails or a pry bar.
      • If you are using a pry bar, it can scratch the screen. Apply gentle pressure until the plastic frame pop out all around the frame. Don't force it!
      • Finally, remove the frame.
      Pregunta a FixBot
      Agregar Comentario
    4. HP Pavilion G6  Screen Replacement, Release the screen from the frame: paso 4, imagen 1 de 3 HP Pavilion G6  Screen Replacement, Release the screen from the frame: paso 4, imagen 2 de 3 HP Pavilion G6  Screen Replacement, Release the screen from the frame: paso 4, imagen 3 de 3
      • Remove the black Philips screw from the top on each side.
      • Remove the bottom screw from the hinge to make an easier access to the screws on the side of the screen.
      • Now that the frame is loose, you can remove the 4 x Philips screws holding the screen in the frame.
      Pregunta a FixBot
      Agregar Comentario
    5. HP Pavilion G6  Screen Replacement, Disconnect the screen connector: paso 5, imagen 1 de 3 HP Pavilion G6  Screen Replacement, Disconnect the screen connector: paso 5, imagen 2 de 3 HP Pavilion G6  Screen Replacement, Disconnect the screen connector: paso 5, imagen 3 de 3
      • Turn the laptop back up and carefully tilt the screen out from the frame and rest it on the keyboard.
      • Don't try to fully remove it yet as it is still attached to the motherboard by the screen cable!
      • Gently lift up the adhesive and disconnect the screen connector. That is the screen released and ready for a change for a new one.
      Pregunta a FixBot
      Agregar Comentario
    6. HP Pavilion G6  Screen Replacement, Check the model number before ordering: paso 6, imagen 1 de 2 HP Pavilion G6  Screen Replacement, Check the model number before ordering: paso 6, imagen 2 de 2
      • Before ordering a new screen make sure that you order the correct model number that is compatible with your old screen.
      • Check the cable connector to make sure you order the correct screen with the correct number of pins.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
2 personas más completaron esta guía.
honakrisi
Miembro Desde 01/28/20
4,441 Reputación
9 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 17
Ultimos 30 días: 62
Todo El Tiempo: 2,280
