Saltar al contenido principal
HP Pavilion DV9700 RAM Replacement
Qué necesitas
  1. HP Pavilion DV9700 RAM Replacement, RAM: paso 1, imagen 1 de 2 HP Pavilion DV9700 RAM Replacement, RAM: paso 1, imagen 2 de 2
    • Turn the device over so that the bottom is facing upward.
    • Locate the three panels near the bottom half of the device.
    • The middle-most panel is the one we will be focusing on.
    • Using a Philips #0 screwdriver, unscrew the two 4mm screws that hold this panel in place.
  2. HP Pavilion DV9700 RAM Replacement: paso 2, imagen 1 de 2 HP Pavilion DV9700 RAM Replacement: paso 2, imagen 2 de 2
    • Pull the bottom of the panel upward.
    • Then pull the panel toward yourself to remove.
  3. HP Pavilion DV9700 RAM Replacement: paso 3, imagen 1 de 3 HP Pavilion DV9700 RAM Replacement: paso 3, imagen 2 de 3 HP Pavilion DV9700 RAM Replacement: paso 3, imagen 3 de 3
    • Look toward the top half of the exposed compartment.
    • Each ram stick will have two silver clips on the left and right side.
    • Push these clips outward at the same time to release the ram stick.
  4. HP Pavilion DV9700 RAM Replacement: paso 4, imagen 1 de 3 HP Pavilion DV9700 RAM Replacement: paso 4, imagen 2 de 3 HP Pavilion DV9700 RAM Replacement: paso 4, imagen 3 de 3
    • The ram stick will be held at a 45 degree angle. Pull the stick upward to release it from the slot.
    • Each ram stick will have a notch near the bottom, make sure to keep note of which side this notch is on.
    • Make sure to place the ram away from any static surfaces (carpet, fabric, etc.)
Conclusión
Max Shangraw
Miembro Desde 03/19/18
507 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 771
