Saltar al contenido principal
HP Pavilion DV9700 Optical Drive Replacement
Qué necesitas
  1. HP Pavilion DV9700 Optical Drive  Replacement, Optical Drive: paso 1, imagen 1 de 3 HP Pavilion DV9700 Optical Drive  Replacement, Optical Drive: paso 1, imagen 2 de 3 HP Pavilion DV9700 Optical Drive  Replacement, Optical Drive: paso 1, imagen 3 de 3
    • Turn the device over so that the bottom is facing upward.
    • Find the screw with an imprint of a disk underneath it. It is located near the center of the device.
    • Remove this 6mm screw with a Philips #0 screwdriver.
    • This screw is very small, make sure to have an organized place to put it.
  2. HP Pavilion DV9700 Optical Drive  Replacement: paso 2, imagen 1 de 3 HP Pavilion DV9700 Optical Drive  Replacement: paso 2, imagen 2 de 3 HP Pavilion DV9700 Optical Drive  Replacement: paso 2, imagen 3 de 3
    • The optical drive is located toward the left side of the device.
    • Using a spudger, pry the optical drive away from the casing.
    • Pull the rest of the optical drive out with your hand.
Conclusión
Una persona más ha completado esta guía.
Max Shangraw
Miembro Desde 03/19/18
507 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 358
