Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
HP Pavilion DV5T-1000 Hard Drive Replacement
Qué necesitas
    • Make sure the laptop is turned off, and the power cable is removed.
    • Leaving the laptop turned on can cause damage to the hardware and any stored data.
  1. HP Pavilion DV5T-1000 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Turn the laptop over to access the backside of the computer.
    • Identify and confirm that the laptop is an HP Pavilion DV5T-1000.
  2. HP Pavilion DV5T-1000 Hard Drive Replacement: paso 3, imagen 1 de 2 HP Pavilion DV5T-1000 Hard Drive Replacement: paso 3, imagen 2 de 2
    • Slide the battery lock to the left, it's located just below the battery compartment.
    • Pull the battery up and out, to remove it from the battery compartment.
    • To prevent hardware damage, remove the battery before working on the laptop.
  3. HP Pavilion DV5T-1000 Hard Drive Replacement: paso 4, imagen 1 de 1
    • Identify the hard drive compartment, located at the top left-hand frame of the laptop.
  4. HP Pavilion DV5T-1000 Hard Drive Replacement: paso 5, imagen 1 de 1
    • In order to remove the hard drive compartment cover, first remove the two screws located on the panel, using a size 0 Phillips head screwdriver.
  5. HP Pavilion DV5T-1000 Hard Drive Replacement: paso 6, imagen 1 de 1
    • Expose the hard drive by lifting the drive cover.
  6. HP Pavilion DV5T-1000 Hard Drive Replacement: paso 7, imagen 1 de 1
    • In order to loosen the hard drive from the motherboard, tug gently on the black tabs located at both ends of the hard drive.
    • Be cautious when handling the cable that connects the hard drive to the computer's motherboard.
  7. HP Pavilion DV5T-1000 Hard Drive Replacement: paso 8, imagen 1 de 2 HP Pavilion DV5T-1000 Hard Drive Replacement: paso 8, imagen 2 de 2
    • Firmly hold both the black plug, and the hard drive itself to separate the drive from the cable.
  8. HP Pavilion DV5T-1000 Hard Drive Replacement: paso 9, imagen 1 de 2 HP Pavilion DV5T-1000 Hard Drive Replacement: paso 9, imagen 2 de 2
    • Remove the 4 screws using a size 0 Phillips head screwdriver.
    • Remove the metal from the perimeter of the hard drive.
Conclusión
8 personas más completaron esta guía.
Josh Taimanglo
Miembro Desde 09/21/15
183 Reputación
1 Guía escrita
Equipo
1Guía Comentario
Help after replacing hard drive installation of windows
Bettyjean Serrano - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 21
Ultimos 30 días: 77
Todo El Tiempo: 2,600
