Saltar al contenido principal
HP Pavilion DV3 RAM Replacement
Qué necesitas
  1. HP Pavilion DV3 RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
    • The yellow highlighted edge of the battery should pop up slightly when the switch is moved
  2. HP Pavilion DV3 RAM Replacement: paso 2, imagen 1 de 2 HP Pavilion DV3 RAM Replacement: paso 2, imagen 2 de 2
    • Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
  3. HP Pavilion DV3 RAM Replacement, RAM: paso 3, imagen 1 de 3 HP Pavilion DV3 RAM Replacement, RAM: paso 3, imagen 2 de 3 HP Pavilion DV3 RAM Replacement, RAM: paso 3, imagen 3 de 3
    • Remove the two 3.5 mm diameter head and 7 mm long screws using the Philips PH1 screwdriver.
    • Both screws will remain attached to the cover.
    • Set the cover with attached screws to the side.
    • The RAM will now be exposed
  4. HP Pavilion DV3 RAM Replacement: paso 4, imagen 1 de 3 HP Pavilion DV3 RAM Replacement: paso 4, imagen 2 de 3 HP Pavilion DV3 RAM Replacement: paso 4, imagen 3 de 3
    • Find the two clips located on each side of the RAM.
    • Using both hands, simultaneously grab each clip and open them away from the RAM stick.
    • The RAM will pop up.
  5. HP Pavilion DV3 RAM Replacement: paso 5, imagen 1 de 2 HP Pavilion DV3 RAM Replacement: paso 5, imagen 2 de 2
    • Using one hand, pull the RAM up and to the left to remove it.
  6. HP Pavilion DV3 RAM Replacement: paso 6, imagen 1 de 1
    • If there is a second RAM module present (as shown), repeat steps 2 and 3 to remove it.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 14-10, Forte Fall 2013 Miembro de Cal Poly, Team 14-10, Forte Fall 2013
CPSU-FORTE-F13S14G10
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 20
Todo El Tiempo: 2,008
