Saltar al contenido principal
HP Pavilion DV3 Hard Drive Replacement
Qué necesitas
  1. HP Pavilion DV3 Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
    • The yellow highlighted edge of the battery should pop up slightly when the switch is moved
  2. HP Pavilion DV3 Hard Drive Replacement: paso 2, imagen 1 de 2 HP Pavilion DV3 Hard Drive Replacement: paso 2, imagen 2 de 2
    • Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
  3. HP Pavilion DV3 Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 1
    • Locate the screw for the hard drive cover (The cover has HP ProtectSmart written on it).
    • Remove the 3.5 mm diameter, 7 mm long screw with your Phillips PH1 screwdriver.
    • The screw will remain attached to the cover.
  4. HP Pavilion DV3 Hard Drive Replacement: paso 4, imagen 1 de 2 HP Pavilion DV3 Hard Drive Replacement: paso 4, imagen 2 de 2
    • Grab the raised edge of the cover lift up. This will separate the cover from the laptop.
    • Put the cover and screw to the.
    • This will reveal the hard drive.
  5. HP Pavilion DV3 Hard Drive Replacement: paso 5, imagen 1 de 3 HP Pavilion DV3 Hard Drive Replacement: paso 5, imagen 2 de 3 HP Pavilion DV3 Hard Drive Replacement: paso 5, imagen 3 de 3
    • With your fingers, grab the clear tab.
    • Pull right first, and then upwards (towards you).
    • The hard drive should slide out of place and detach from the laptop.
Conclusión
5 personas más completaron esta guía.
Luke Whitmarsh
Miembro Desde 09/30/13
649 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 14-10, Forte Fall 2013 Miembro de Cal Poly, Team 14-10, Forte Fall 2013
CPSU-FORTE-F13S14G10
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 4,985
