Introducción
This guide will show you how to successfully remove the wireless card from the laptop. You will need the screwdriver listed in the tools section.
Qué necesitas
Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
The yellow highlighted edge of the battery should pop up slightly when the switch is moved
With the laptop upside down, locate the three screws on the wireless card cover and unscrew the screws.
All three screws will have a 3.5 mm diameter head.
Two of the screws will be silver, 7mm in length, and will stay attached to the cover.
One screw will be black, 13mm in length, and will separate from the cover. Set this screw aside.
Una persona más ha completado esta guía.
