Saltar al contenido principal
HP Pavilion DV2160BR Wifi Adapter Replacement
Qué necesitas
  1. HP Pavilion DV2160BR Wifi Adapter Replacement, Wifi Adapter: paso 1, imagen 1 de 2 HP Pavilion DV2160BR Wifi Adapter Replacement, Wifi Adapter: paso 1, imagen 2 de 2
    • Start with the bottom of the laptop facing up.
    • Locate the small panel under the battery, which houses the wifi adapter, and unscrew the one 5mm Phillips #0 screw holding the panel in place.
    • Remove the panel and set it aside.
    • Be careful not to snap the 2 tabs on the sides of the panel when pulling it out.
  2. HP Pavilion DV2160BR Wifi Adapter Replacement: paso 2, imagen 1 de 2 HP Pavilion DV2160BR Wifi Adapter Replacement: paso 2, imagen 2 de 2
    • Unscrew the two 3mm Phillips #0 screw which is located at the corners of the wifi adapter.
  3. HP Pavilion DV2160BR Wifi Adapter Replacement: paso 3, imagen 1 de 2 HP Pavilion DV2160BR Wifi Adapter Replacement: paso 3, imagen 2 de 2
    • Pull the 2 black wires with the gold pieces out of the wifi adapter.
    • The wifi adapter is now free to be removed.
    • When reconnecting the wires for re-installing the wifi adapter, make sure the gold ends are rotated correctly to be properly pushed back in.
Conclusión
Una persona más ha completado esta guía.
Shannon
Miembro Desde 04/11/13
55 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 13-66, Johann Spring 2013 Miembro de Cal Poly, Team 13-66, Johann Spring 2013
CPSU-JOHANN-S13S13G66
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 533
