Saltar al contenido principal
HP Pavilion DV2160BR RAM Replacement
Qué necesitas
  1. HP Pavilion DV2160BR RAM Replacement, RAM: paso 1, imagen 1 de 2 HP Pavilion DV2160BR RAM Replacement, RAM: paso 1, imagen 2 de 2
    • Start with the bottom of the laptop facing up.
    • Locate the panel that is covering the RAM compartment.
    • Unscrew the two 5mm Phillips #0 screws that are securing the RAM compartment.
  2. HP Pavilion DV2160BR RAM Replacement: paso 2, imagen 1 de 2 HP Pavilion DV2160BR RAM Replacement: paso 2, imagen 2 de 2
    • Lift up the panel that is by the end that held the screws. Set it aside.
  3. HP Pavilion DV2160BR RAM Replacement: paso 3, imagen 1 de 3 HP Pavilion DV2160BR RAM Replacement: paso 3, imagen 2 de 3 HP Pavilion DV2160BR RAM Replacement: paso 3, imagen 3 de 3
    • Using 2 prying tools, push the 2 buttons on the sides of one RAM module simultaneously, so that one side of the module pops up and out of the clips holding it down.
    • Grab the RAM module and carefully pull it straight out of its slot.
    • Repeat this step for the second RAM module, which is located just underneath the first RAM module.
Conclusión
Shannon
Miembro Desde 04/11/13
55 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 13-66, Johann Spring 2013 Miembro de Cal Poly, Team 13-66, Johann Spring 2013
CPSU-JOHANN-S13S13G66
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 382
