Saltar al contenido principal
HP Pavilion DV2160BR Hard Drive Replacement
Qué necesitas
  1. HP Pavilion DV2160BR Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 2 HP Pavilion DV2160BR Hard Drive Replacement, Hard Drive: paso 1, imagen 2 de 2
    • Start with the bottom of the laptop facing up.
    • Locate the panel covering the hard drive compartment.
    • Unscrew the two 5mm Phillips #0 screws.
  2. HP Pavilion DV2160BR Hard Drive Replacement: paso 2, imagen 1 de 1
    • Lift up this external panel by the end with the screws and set it aside.
    • Be careful about the four plastic tabs holding the panel on the device.
  3. HP Pavilion DV2160BR Hard Drive Replacement: paso 3, imagen 1 de 2 HP Pavilion DV2160BR Hard Drive Replacement: paso 3, imagen 2 de 2
    • Locate the second plastic panel covering the hard drive.
    • Unscrew the two 4mm Phillips #0 screws holding it in.
  4. HP Pavilion DV2160BR Hard Drive Replacement: paso 4, imagen 1 de 1
    • Lift up this internal panel using the plastic white tab and set it aside.
  5. HP Pavilion DV2160BR Hard Drive Replacement: paso 5, imagen 1 de 3 HP Pavilion DV2160BR Hard Drive Replacement: paso 5, imagen 2 de 3 HP Pavilion DV2160BR Hard Drive Replacement: paso 5, imagen 3 de 3
    • Grab the end of the hard drive and pull it up to a vertical position.
    • Gently slide the Hard Drive off of the SATA connector.
    • Warning: Don’t wiggle the SATA connector or the top piece will come off. If it does, reconnect it vertically.
Conclusión
Una persona más ha completado esta guía.
Shannon
Miembro Desde 04/11/13
55 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 13-66, Johann Spring 2013 Miembro de Cal Poly, Team 13-66, Johann Spring 2013
CPSU-JOHANN-S13S13G66
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 536
