Saltar al contenido principal
HP Pavilion DV2160BR Battery Replacement
  1. HP Pavilion DV2160BR Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Start with the bottom of the laptop facing up.
  2. HP Pavilion DV2160BR Battery Replacement: paso 2, imagen 1 de 2 HP Pavilion DV2160BR Battery Replacement: paso 2, imagen 2 de 2
    • Locate the battery compartment at the rear of the device.
    • There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
Conclusión
Shannon
Miembro Desde 04/11/13
55 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 13-66, Johann Spring 2013 Miembro de Cal Poly, Team 13-66, Johann Spring 2013
CPSU-JOHANN-S13S13G66
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 302
