Saltar al contenido principal
HP Pavilion DM4 Hard Drive Replacement
Qué necesitas
  1. HP Pavilion DM4 Hard Drive  Replacement, Hard drive: paso 1, imagen 1 de 2 HP Pavilion DM4 Hard Drive  Replacement, Hard drive: paso 1, imagen 2 de 2
    • Unlock and remove the battery pack.
  2. HP Pavilion DM4 Hard Drive  Replacement: paso 2, imagen 1 de 3 HP Pavilion DM4 Hard Drive  Replacement: paso 2, imagen 2 de 3 HP Pavilion DM4 Hard Drive  Replacement: paso 2, imagen 3 de 3
    • Unscrew the hidden screws covered by the battery pack and remove the panel to find more hidden screws.
  3. HP Pavilion DM4 Hard Drive  Replacement: paso 3, imagen 1 de 3 HP Pavilion DM4 Hard Drive  Replacement: paso 3, imagen 2 de 3 HP Pavilion DM4 Hard Drive  Replacement: paso 3, imagen 3 de 3
    • Unscrew the hidden screws in order to remove the hard drive cover.
  4. HP Pavilion DM4 Hard Drive  Replacement: paso 4, imagen 1 de 1
    • Pull out the tab to remove the hard drive.
  5. HP Pavilion DM4 Hard Drive  Replacement: paso 5, imagen 1 de 3 HP Pavilion DM4 Hard Drive  Replacement: paso 5, imagen 2 de 3 HP Pavilion DM4 Hard Drive  Replacement: paso 5, imagen 3 de 3
    • Take the hard drive out and pull the connector from it.
    • In order to disconnect the hard drive, grab the hard drive and cord then gently pull the hard drive away from the cord.
  6. HP Pavilion DM4 Hard Drive  Replacement: paso 6, imagen 1 de 1
    • Replace the hard drive.
    • Do not take apart the hard drive if you want it to run anything at all!
Conclusión
8 personas más completaron esta guía.
Un comentario
I need to replace the hard drive and was wondering how large can the DM4 handle. It is currently 578Gb and it would be great for 1 or 2 TB. Thanks
epascual1960 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 30
Todo El Tiempo: 7,880
